1 - 20 of 30 Posts
So I just bought a used s16g. I didn't know when I got it that it would have big cracks in the hot side.:chair: How much will it effect boost creep? Should I have the cracks welded up?
Every one I have seen has cracks like that or worse.... I don't know how much it will affect boost though?
Discussion Starter · #5 ·
ALLWheelDrive69 said:
You won't boost creep because of those cracks. Thats allowing more air to get past the waste gate which equals less boost. :)
Less boost :mad: How big of a problem will it be? I just want to run 15psi for now. What do you think?
You're screwed. Not going to lie. Best way to deal with that is go External on the o2 housing means you can rip out the flapper and not worry about the crack anymore.
Discussion Starter · #10 ·
So basically I got ripped off?? I don't want to spend more money on an external.
Yep. I have like 1/2 the cracks on mine...
Just put up a WTB thread for an EVO hotside. You'll be fine with that. I got one off a member here for $80. Should give you an idea.
Discussion Starter · #12 ·
Weird. Why are some people saying its fine and others that its not...Who to trust??:dunno: Ive heard "when you are building boost that the waste gate flapper is partly open anyways to maintain the boost level you want.
if anything it should help you eliminate some creep." That makes sense to me?
Every car is different. When I pulled off my 16g the wastegate had cracks around the seal as well. Mine weren't as bad, but you have to think about what is actually going on inside there. Mine was working fine, yours could too. Yours could also work like garbage. Best thing to do now is throw the thing on and see what happens, since you already have it....unless you can get your money back. Either way, cracks are going to develop no matter what.
....those are some really nasty cracks, though. Can you weld something like that? ....prolly not.....:confused:
:eeek: You could try to port it. Looks like surface cracks haha.
It comes down to you. I personally would get my money back. But since you're in this situation. Try using it.
Get your money back. Cracks those deep will more than likely affect the performance of the turbo in one way or another. If you're looking for another 16g hotside, I've got one. PM me for details.
With this statement above, it is obvious that you don't completely understand the operation of an internal wastegate. Who to trust??? Yourself once you gain the information.
The crack is located on the internal wastegate flapper gate. The gate is there to keep exhaust gases from exiting out that hole until the desired boost level is achieved.
Example:
If you have a 10 PSI wastegate spring, then when boost pressure reaches 10 PSI, the gate will open. It won't open at 5 PSI, not even slightly open as long as the wastegate is working properly. This is so that you can reach the desired boost level as quickly as possible.
Now with those cracks in the wastegate port, you now have a constant exhaust leak that allows some of the gases away from the turbo. You want 100% of the exhaust pulses turning the turbo. If 20% of the exhaust pressure is leaking out the crack, the turbo will spool 20% slower. That's not even the worst part, because the turbo will need to work 20% harder to achieve the desired boost. The harder the turbo works, the more heat it creates which will cause your intercooler to heat soak earlier and promote harmful detenation to the motor.
Now, do you think it is OK to have those cracks?? Trust yourself yet??
Example:
Awesome explanation. :)
Discussion Starter · #18 ·
Example:
Great stuff, thanks for the information! I had just thought there was always some air flowing threw so it "might" be okay. I asked the guy for my money back but he told me it was sold "as is" which wasnt part of the agreement but I guess I should have asked about the hot side before I bought it :chair:. Anyways now the search starts for a hot side...thanks again!
While this is not quite the same problem, I figure someone would know the answer to this: How does a waste gate flapper arm get bent to the point where the flapper doesn't cover the whole hole, and how do you fix it? Can I bend it back?
If you'll notice, there's a small, crescent shaped opening on the right side of the WG flapper. Ideas?
1 - 20 of 30 Posts
