1 - 7 of 7 Posts
As part of my move to a NLTS system on my Evo 1, I've put an order in for a brake light switch which I'm going to hook up to the clutch pedal to activate it. However, when this switch arrives, I'm only going to have 1 day to fit it and test it before a drag tournament. How simple is it to attach a switch like that to the clutch pedal? The wiring won't be a problem but just want an idea of how easy the physical fitting is going to be as I'll be working with a strict time limit. I know the DSMs might be a little different, but any advice you could offer would be appreciated.
Thanks in advance :)
mmmm. I don't know about the evo 1 but in 1g's theres a switch on the clutch pedal. so when someone push it, the car can be started. IF there is one of those switches in that evo, could you hack on it!!!??
If your using a Keydiver Chip and using his clutch wire for studder launch. What I did was splice the clutch wire into my handbrake switch. With handbrake off it would studder at desired launch rpm. As soon as I let out the clutch I would one click the handle up to disengage studder rpm. I don't know what this do NLTS with the break handle still one click up. I also drive with the break handle one click up so I don't hit my launch rpm.
1 - 7 of 7 Posts
