I just measured a cap full of oil and my Castrol bottle gives me just over a teaspoon which is 3-6 times less than the FAQ's recommended 1-2 tbs.
FAQ compression test
I use a cap full as well.Eric S said:I just measured a cap full of oil a
You're right but after a few cranks of the engine I think the oil would spread around a lot.AXiS said:Well I guess you would need enough to get to the rings, the tops of the pistons are kinda sunken so if you didn't put enough i think the oil would just pool in the middle of the pistons.
I would go with DSM specific number rather than some random mechanic.Eric S said:My mechanic says his shop manual specs the pressure at between 140-145psi.
That makes sense. My 140psi compression numbers are even accross all cyclinders but the FAQ says 164psi is what I should have so it had me wondering.nukefission said:As mentioned, we have dish pistons and as such the wet test doesn't do a whole lot for us. Compression is artificially raised whether you add a little or a lot of oil, it doesn't matter. The wet test is inaccurate and really doesn't tell you anything useful. If you had a low cylinder and did a west test, the compression would be bumped up and you'd say "the rings are shot" and go to the trouble of rebuilding the bottom end when really the problem was a burnt valve or seat in the head.
Also as mentioned, your compression numbers are pretty even across the board, so no worries. If you really want to get specific, invest in a leakdown tester and do a leakdown test (requires compressed air). This is the only way to know what's really going on in your motor. I speak from experience.
I get 180 across the board. But I think that is from a ton of carbon build up...turbo8765 said:I've never seen a 1g with 160-165, not saying they're not out there, but I've never seen one.
Time for MCCC.thegreatms said:I get 180 across the board. But I think that is from a ton of carbon build up...
carbon = bad![]()
Done. Not much help.turbo8765 said:Time for MCCC.
