your gonna need alot more booty to make a dsm do 10's. especially if you dont have the car yet. or at least do 10's and be able to keep the car running.
almost exactly what it sounds like, its an intercooler where the intercooler is encased in a shell that contains water, and you use a remote water tank loaded with ice to circulate cold water into that case ..... allowing you to use 40* water instead of 90* air (or what ever the temp is outside that day)axemurderer said:What is a Bullet style liquid to air intercooler? this thing looks like a get option instead of getting a front mount. How does this thing work?
Keymaster said:But realize how much weight reduction they've done. That car is stripped on the inside. For a track only car that's great, but for a DD, it's totally impractical. Also, they are REALLY pushing the limits on that turbo, and it likely won't last much longer.
its one of those things that could go either way .... my brothers 14b lasted 10 minutes at 20 odd psi when the bost controller failedTom N. said:Thats what the guy who made this post is looking for, a track only car.
As for the turbo not lasting much longer. Well we have been hearing that for a year or so now.![]()
hotrodkid said:its one of those things that could go either way .... my brothers 14b lasted 10 minutes at 20 odd psi when the bost controller failed
id say a 16g would be faster and less likely to fail anyways .... and its not like a used 16g is gonna add that much to the total budget anyways
well in the name of making sure your car is as fast as possible, im making a 14b voodoo doll ... im driving railroad spikes thru this 14b turbo i have laying aroundTom N. said:You will have to have faith in the fact that we know a 16g will be faster.![]()
There is a 16g sitting ready to go on the car when the 14b thing is done.
hotrodkid said:well in the name of making sure your car is as fast as possible, im making a 14b voodoo doll ... im driving railroad spikes thru this 14b turbo i have laying around![]()
Now that's just awesome. Says a lot to the ppl with hopes on building a car instead of just flaming about you need this that and you aint got none.Tom N. said:Actualy it can be done for half of that if you can do the work your self.
Here is the blue print.
http://www.94tsiawd.com/Goodwill1.html
Dont let people discourage you.
You can build one hell of a fast car from these platforms with not alot of money if is going to be a track only car.
Good luck and have fun.
