Yes Adam, you need to change it. In order to recirculate, you need to find a way to connect that "horn" to your intake pipe. So, unless you can weld a piece, it will not hold a tight enough seal no matter how you put in a hose. You could try to insert a large barb fitting or nipple in that horn and then put a hose in it?
