HX35 with 9cm .55 A/R BEP turbine housing. I got the center section and compressor housing from mark @ trkperformance (says 35k of miles). The manifold is ceramic coated t3 turbonetics. I have a -10 SS braided line (~18" with t3/mitsu adapter plates for the drain. Also included is: T3 gasket, coolant line plugs (HX35 just oil cooled), 38mm outlet flange (drilled) with piping welded on - seriously about everything you need aside from and O2 housing (mitsu), 38mm wastegate and a feedline. I will also include a 3" to 4" adapter for you guys not running 4" intake pipes.
For pics and more info: http://www.dsmsource.com/classifieds/showproduct.php?product=34273&cat=2...
Thanks guys
Discussion Starter · #3 ·
sold - thanks guys
