Ignition Timing Control
507 Views 3 Replies 4 Participants Last post by  ender
I am looking for an aftermarket ignition timing controller and wanted to know what you all are using and what is out there. I have a safc and want to take the stock pcm completely out of the picture with a stand alone ignition unit. Any recommendations? Also, what about keeping the stock pcm and just taking it out of the loop on fuel control. Has anyone had any pcm issues by doing this? Any help appreciated.
You can do both, as long as your willing to take the time to do the programing. Haltech has a few different options. For the easiest/best I would say just go with an AEM unit. I've been very happy with mine.
For just timing control look into the Apex'i ITC. It is a piggy back timing controller. The only one that I can think of actually.
the perfect power SMT-7 can also control timing. it also has an option to get rid of the MAS altogether and run the system as speed density. not sure if it can handle karmann meters though- it might be voltage only.
i've been toying with a few circuits that can modify output pulse width.. this would allow a tuner to change the output side of the ECU to compensate for larger injectors instead of screwing with the load signal, so you can modify fuel as much as you want and leave the timing maps intact.
