Just redid timing after belt skipped. Valve did hit pistons, comptest showed that only number 2 piston was below (120). Car idling great, but was lacking some power. Then...
Today, I drive it to work, still no power. On the way home, even less power. Did notice a bit of smoke coming from ex. mani. after each drive.
ON the way home, the temp* is waving around, no power at all (barely make 40mph).
Get home and pop the hood:
1. Oil pool in valve cover
2. Oil on the hood heatshield
3. Oil shot out of the breather valve filter (on outside of IC pipe.
4. Coolant is bubbling in resevoir.
5. Smoking from ex. mani.
6. At full throttle, no power still, and boost still rises.
7. Timing is still perfect
I am really at a loss with this. All I can think of is either headgasket, rings on #2 cyl., or crankcase ventilation.
Recently, I have done the BS removal, new oil pump and case, changed all 8 intake valves, changed out old MAS with used one. REbuilt like 4 months ago, only problem from then was no boost, which was fixed.
What the F*** is going on??? (sorry for long post)
