For the past 25k miles i've had no pcv valve, i just put a 90 degree barb in there and then ran a hose from that barb to my catch can with a breather and also the line that goes from the side of the valve cover to the catch can with the breather. You'll find alot of people with it done up like this. It's wrong, and i didn't discover this until just last night.
Think about this for alittle bit....yes, it's ventilating the crank case pressure and it's doing it well enough to make the dip stick pop out and it's doine it well enough to accumulate some oil in the catch can after a few weeks, but the nasty gases remain floating around in the valve cover damaging and breaking down the oil....
This is where an evacuation system is needed. A force is needed to suck everything floating around in the head out of the head and into a sealed catch can. How does the sealed catch can produce a force to suck? From vacuum supplied to your intake pipe before the turbo. Vendors mostly sell them without the barb on them because the idea is to eliminate the oil in your intake system. That's understandable as the stock hose goes directly from the valve cover to the intake, so all we have to do is still something to take out the dirtiness before it get's sucked into the intake. Leave the pcv valve alone and have it hooked up to the IM, because it's doing you good. It's sucking out the fumes into the IM only under vacuum and when the IM shows +pressure then the ball shuts in the valve and the pcv valve closes so your not shooting a bunch of pressurized air into your valve cover. Now the evacuation system is left to the vacuum source from the intake pipe before the turbo, which always has -pressure.
Some of the crankcase pressure could cause blow by on worn rings, it may even cause more heat in the engine leading to perhaps detonation.
, it's been discussed many times before but i think alot of people don't think about it enough.
