had to disconnect the battery. now need to input radio code. i read the manual but the stupid instructions are confusing. can anyone explain in laymen terms how to set the code? Here is what the instructions says:
"Press NO.1 through NO.4 memory select button (3) to set four-digit security code indicated on card. Every time each digit is pressed, the figure changes as follows: 0 - 1 - 2.....9 - 0. Press TAPE or CD button (4), and a beep will be heard and the audio system will be in the operating condition...."
I tried it and it still won't work. I pressed buttons 1 - 4 then the code and pressed TAPE but it won't work. Am I doing it wrong or did the dealer give me the wrong code? Thanks for you help and sorry its so long.
