I am trying to change my bulbs and in order to take of the headlights I need to take off the bumper. Or is it easier just to take the bulb out itself by removing the two screws? Its a 2g eclipse
You don't need to take the headlight out to change the headlight bulbs. You just twist the cap behind the bulb and pull the assembly out. There should be decent instructions in the owners manual...
I can't believe you would even need instructions for it. There is a plastic cap on the back of the housing. Turn it counter clockwise and remove it. Unsecure the bulb and remove it. Go in reverse. No screws need to be removed during the process.
