Your transmission takes ATF-4 or if you go to a dealer, you can buy Diamond Star ATF.
Normal maintenance is usually a timing belt, water pump, sometimes a reman oil pump. Check tie rods, wheel bearings and all the stuff. When purchasing a car you should also change every fluid in the car, you have no idea of knowing what or how long anything has been in there.
