I just did the headgasket and timing belt on my 92 Talon, when pulling the head off I pulled the wire frolm the knock sensor apart, so I crimped the 2 wires together and assumed it would be OK. Once I started the car the check engine light came on so I read the codes and it points to the knock sensor.
My questions is has anyone done this before without the check engine going on? Can this wire be spliced without changing the resistance of the sensor or causing it to malfunction?
Thanks
Thanks
