Knock sensor=gooey?
1183 Views 12 Replies 9 Participants Last post by  greenstreak
I've noticed some goop/oily residue coming from my knock sensor. I assume this means time to replace. I'm having some problems tuning my car right now (can't smooth things out), after installing 550 injectors, fuel pump, etc. using a S-AFC II. Is it possible that my knock sensor is mal-functioning causing my timing to be pulled? Where can I get one for cheap?
1 - 13 of 13 Posts
that's exactly it. When the knock sensor becomes googy it pulls timing if i am not mistaken 9 degrees,get it replaced asap
The fluid is what the inner sensor floats in (I believe).
So if its bouncing around without the fluid there to slow its movement it'll retard timing a varying degree depending on how much noise it 'hears'. Personally my knock sensor accidenttally got yanked out during a clutch swap and threw a CEL.
I believe I got a new one for 56 bucks or so from JNZTuning (see greenstreak) here on the board.
on my knock sensor on the back of it. its soft to the touch does it mean that i have to change it soon ?
I figured that's the issue. Is all I need a xxMM wrench to replace it?
22mm maybe? But yes, if it is all gooey it is done.
I think its bigger than 22mm.
I used an adjustable that when it FINALLY cracked loose it flew up (the wrench) hit me in the face, and almost knocked me unconscious. Me and knock sensors haven't gotten along since. Mine was gooey as well. It also worked for shit. My 1g couldn't pull timing fast enough, then blew its own head off. I don't have a log, but I don't think it even pulled timing. Just BOOM... cough... sputter, and spyhunter. ^ That above was me just trying to get it out of the empty block... so I could replace it later when I built another 6 bolt. :mad:
That sucks! I'll break it loose though N/P. I broke loose crank sprocket with a weeny 1/2" drive socket and after that nothing seems too difficult. :D I need this sensor ASAP, no dealer in my area stocks them...and if they did, they want almost $100 for it?!! :eek:
I just used a cresent wrench to get mine off. Enjoy they are so fun to get at!! LOL
Shane
whats the location of the knock sensor on the 1g's??
on the back of the block twords the fire wall under the air intake manifoldand if u have a dsm manual cd look up detonation sensor..i pulled my head with the intake attached and well if u are not care full it will pull that wire right outa of the sensor the cheapest i have found it so far was at autozone part number su3303 its about $52.99 sigh ..and if it is gooy dont drive ur car it may change the timing so much u might end up with some bent or chiped valves..sigh...combanation timing belt and gooy knock sensor killed my head sigh.....
joel
oohh and the price for the knock sensor(detonation sensor) and most places range from $130 to $52
Not if you are smart it doesn't.
www.jnztuning.com
Support DSMtalks sponsors.......and save a few bucks in the process.
1 - 13 of 13 Posts
