There should be a hole by the #3 cylinder where it can be mounted to the block. On the same side as the turbo block, just a different spot.firestarter4206 said:
Mike
There should be a hole by the #3 cylinder where it can be mounted to the block. On the same side as the turbo block, just a different spot.firestarter4206 said:ok there is no knock sensor on a 1g n/t model and i was wondering if there is a way to wire a aftermarket knock sensor without changing the wiring harness
