I have a Talon Esi FWD. The noise is only there when you step on the gas and for a second on startup. No noise during idle but as soon as you touch the strange knocking/grinding noise that just recently started on my 1992 gas it starts.. Its a loud knockin/ticking noise defently coming from the timing belt area. Its not lifter tick, ignition knock, or a bearing noise. When u rev beyond about 2000rpm u can actually hear a bit of a grinding sound. I know defently my auto tensioner is shot (brand new) but the part has been recalled. Im curious if this part could be causing a knocking noise as i step on the gas to increas rpm causing the timing belt tension to change and not giving the tensioner enough time to adjust? Im really stuck on this right now as i cannot get the replacment part yet as it is not even available! The car is off the road till i figure this out.. if not the timing belt tensioner the only other things i can think of are the oil pump and balance shafts. but oil pressure is fine.. engine runs fine other than this knocking noise. The noise is 100% coming from this area. also the timing did not jump all the valves are fine etc. Can aynone help me out or had this prob before???
