1 - 5 of 5 Posts
New clutch and release bearing/slave.
Won't bleadm what am I doing wrong. I'm toping up the brake resivoir. bleading is good and stead stream. I've bled 2 full bottles. but there is no action on the clutch. It's staying engaged the whole time. I need help asap.
Discussion Starter #5
Is this because they pull instead of push?
yep, but more specifically
It's because it's an internal slave right on the release bearing. So the blead nipple is prior to the slave. (in between the slave and the resivoir) The vaccum will pull the air out of the slave and the resivoir, but if you just pump the peddle it won't get that far. You will just pump it through some line and out the bleader.
1 - 5 of 5 Posts
