ok i set crank so its at TDC and then the cams are off also though. if i move the crank will i be able to move the cams more so that they feel like they are centered? I tried to move the exhaust and intake over so that they match notches but it wont stay in that position. So if i move the crank just a small bit...will i be able to move the cams to align up so they stay in place?
Ex. Cam marks are both a bit higher than the head on the engine...is it supposto be centered with the center of the cam bolts or the top where the dowel pins are? so if i simply move the crank pully a bit then will i beable to align the cams like i said before?
Where the cams are stopped right now...the crank is almost exactually TDC (or matching the timing marks) but this could be out of phase correct? if i rotate it one way or another, will i be able to get the cams even with the top of the head?
Thanks and this IS my first timing belt job! I love DSM's!!!
Sorry for posting this but i searched and didn't find anything that has to do exactually with what i posted...
