Are you running it as a DD or only on the track?
If it is only a 1/4 mile car you could get away with just running a reservoir filled with ice water. If you ever plan on running it as a DD or even on the highway you need a heat exchanger to bring the water back to ambient temp. The heat exchanger may cause cooling issues; you might have to get more fans and a better radiator. You won't know until you put it in.
