A dremel is a tool made by Black and Decker I think. You can put all different kind of attachments on it to sand, polish, and port stuff. You can do all kinds of stuff, but in your case you use it to enlarge the hole from 52mm to 60mm.Slappster said:Uuhhhh. Dremeling consists of exactly what?
I don't need a triple a - pillar. I want a double 60 mm. Any other places to find them?
I know what the tool Dremel is. What I meant was do you just hollow out the inside of the pod for it to fit?ChicagoGSX said:
Can't find them anywhere. Even from those stores.SeatownGST said:Yes. You simply choose a grinding bit and remove a little material in a circular fashion. You just have to be careful.
Dual 60mm pods are also available from Road Race Engineering, Buschur Racing, and Autometer directly, probably even Options Auto Salon and NOPI.
Probably better to just get the correct size than worry about resizing !
Good luck.
