Logs
540 Views 2 Replies 3 Participants Last post by  rancid1g
Ok so i finally got my ebay datalogger kit working. Seems like i cant connect it to my car without resetting the ecu (pulling negative off batt.) i think its because i got a cell on for my 2nd o2 sensor. but even after it sometimes takes a while for it to connect aswell. im using a palmIIIx with obdgauge1.9
how does it look? (evo16g 10psi)
RPM MPH/timingadvance/intakeairflow/ throttle position
2304 20 26 0 3
1892 23 28 0 9
2088 25 11 0 93
2568 31 11 0 94
3248 38 7 0 94
4020 49 11 0 97
4764 56 12 0 97
5392 66 16 0 98
5988 72 19 0 99
5604 80 34 0 0
4504 79 23 0 0
2344 72 16 0 0
976 63 10 0 0
Your log is a little funny...You logged some things you didn't need to
Log again and start it at 3k and go to around 6-6k...Only log timing, airflow, rpm and 02v which is optional, that's it...This way you will get more data
Also, I didn't see your airflow number go up...it stayed exactly at 0 for the whole time...
Either way, unless you have absolutely no fuel mods, raise the boost!! You have no reason to tune for such low boost, you won't be making that much power...If you really don't have fuel mods, then there is no reason for tuning anyway since you won't be able to add much fuel...
knock please-plus 10 psi is wasting boost,you can run extremely safe at at least 15
