Lost to Nissan 200SX S14
1303 Views 10 Replies 9 Participants Last post by  0lmytsi
Hi,
saturday night I raced vs. my friends Nissan S14. He is stock except the intake and no cat.
I have a 2,5" full exhaust with dp, intake, Greddy Iridiums, Turbo XS BOV, stock boost.
I jumped from the start, cause of my AWD, but on the second gear I got killed and couldn't catch him niether in 3rd or in 4th gear.
I don't like this fact, have to do something.
1 - 11 of 11 Posts
I think its your driving. I can see no other reason for this.
stock on stock with a 130k automatic tranny I could still easily take a 200sx neglecting the 100lbs + sub box.
he said s14, not if it was a 240sx then yah you might have a problem, with an s14 should take out your car with your mods
Do you mean the Silvia S14? Seeing your location, I'm guessing the car you raced is turbo, correct? I think we need to know what kind of car it is you raced exactly...because here in the US a 200SX has about 120hp and there's no way in hell it could take a TSI.
yeah if you meant the 200sx then ill laugh at you..but if its the S14 in fact its okay that you lost
Im guessing your probably on stock fuel set up and about 15-16psi on stock t-25? If not turn the BOOST up to 16 or until right before you start to get fuel cut.
You should be running a stock sr20det anyway, maybe you need a harder launch beacuse with the current set up^^^, you have to be in the high 13's at least! Are you sure it was stock?
I think its time for BIGGER,injectors, fuel pump,fpr,some type of fuel controll and a bigger turbo! :D Lets hope it wasn't a base model 200sx!!! :rolleyes:
Since he is in Lithuania, then it was the 200sx with 1.8 Turbo RWD and 169hp stock :D
i thought 200sx meant 2.0L
and the 180sx meant 1.8L?
and isn't a S14 a Silva?
LatDSM- If we will meet some day, I'll show you my driving skills. ;)
LatDSM - since you are in Latvia, you should know, that Nissan 200sx S14 has 2 liter TURBO engine and the one you was talking about was an earlier model that had 1.8 TURBO - that one is S13!
turbolover: Yes I think so too. I'll wait till spring though.
The car I was racing with was almost stock Nissan 200SX S14, 2.0l Turbo RWD stick shift. It has 200 hp from the engine.
180sx 200sx and 240sx technicly are supposed to designate engine sizes, but diferent countries got different stuff in the end
if it was as s13 s14 or s15, it could also be called a silvia
but some 200sx's arent silvias at all, because they are fwd, and all s13/14/15's are rwd
its kinda a hodge podge of names, and all o know for sure is the american stuffs
240sx = usdm = ka24de
180sx = ca18det
200sx known as silvias = sr20det and yes an sr20 car should take ur heavy awd if u are on the t25...14b might be another story.
1 - 11 of 11 Posts
