1 - 9 of 9 Posts
Ive tried searching.. either im reading it wrong.. or i dont understand it. I have a tial 44mm gate with a 6lb spring, SlowBoy Racing MBC, now my source comes from the J pipe. My question is how do i run the vacuum lines so that i can see 15-16psi?
The botton port on my MBC goes to the J pipe, the side port on my MBC goes to the side port on the wastegate, top port is VTA. is this correct? with this set up i am seeing infinite boost.. or somewhere over 20psi.
Discussion Starter · #9 ·
took the wastegate apart noticed the side port screw was rubbing against the diaphram. so i put 2 more washer in there, put it all back together.. still didnt work. so ill just buy a hallman MBC i guess.
1 - 9 of 9 Posts
