I have it setup up like OEM with the canister and link but want to go to a manual setup.
Since if you hook a vacuum line directly from the actuator to the manifold, it'll be close till boost hits. Once it hits the valves open, now what If I put an inline MBC in that vacuum line and set it to 15psi?
Would this work? Since the MBC is only one way flow that wouldn't give the valves vacuum to close the runners would it?
Just a thought.
Just a thought.
