1 - 8 of 8 Posts
Actually it's a bit more complicated than that....
The engine, 4G64 NA, I'l spare the details on the mod's, they're extensive. The relevant issue is since a complete rebuild, and putting in 880 CC injectors, If I floor it, engine sputters and coughs, If I let up to about half throttle it will run and accelerate nicely and will let me roll the throttle up to about 3/4 and then start the coughing and sputtering again.
I'm oscillating between the timing being too advanced and crappy stock fuel pump. maybe a little of both. I'm compensating for the bigger injectors with a SAFCII, the E-prom is for 450CC injectors, so the fuel is dialed back, also the plugs are showing lean
You cant compensate enough with a safc for the 880cc injectors. You are running rich with no boost and lean during due to the fact you still have the stock fuel pump.
Discussion Starter · #4 ·
Well, Its a normally aspirated engine, so it isn't rich with no boost. I am leaning toward the stock fuel pump being "inadequate" . any comment about the SAFCII affect on timing? I'm dialed back to -25%
I believe you are getting knock from running to rich.
What computer are you using with your MM?
Discussion Starter · #6 ·
ECU is a Stock e-prom unit. The prom is a custom job from Tom Dorris at DSMLink.
I ordered a Walbro 255 yesterday.
I have a AEM 30-1300 unit sitting on my desk at the moment.
I have to make my truck look like an Eclipse for it to work.
But thats going to be another thread.....
Injector size is totally irrelivent to the stock pump, if you aren't making any more power than what the stock pump can handle than you don't need a bigger pump to run the larger injectors, they will be running real low duty cycles.
Discussion Starter · #8 ·
I am making more power, I'm aware of BSFC. Since I'm outputting more than twice the Horspower of stock (116HP), and not knowing the numbers of the stock fuel pump, I thought it a prudent upgrade. What bothered me was the lean condition on the plugs, and the total lack of function at WOT. The stock setup is 275CC injectors, on that setup I had to add 35-40% more fuel via the SAFCII ,went to 450's was still in the +7-10 range,and now I'm at 880 in anticipation of a Turbocharger. Yes I ran NA to check out the build. I was at -25% up to -10 % with the 880's. I was expecting a really rich condition, and to come up lean made me think fuel delivery and or timing. Timing more the problem at WOT. but not sure....Oh well what's another $100 into a race car...
1 - 8 of 8 Posts
