first of all i'd like to tell you i didnt search for over an hour, i tryed to not have to post a topic.
anyway here it goes,
i misshifted from top of 3rd gear back into 2nd, as soon as i realized what happened i pushed the clutch back in, but the car died.... pulled over and it started back up, BUT the idle wouldnt hold.... i had to raise the idle on the TB to get it to idle again.
everything seemed to be fine, but when i started it the next morn it seems to be smoking a little bit.
so i figure i bent/floated a valve....
it stopped smoking after letting it idle for a little while so i decided to take it out for a drive to see if anymore trouble would come up,
out on the drive the car ran flawlessly, but after 15 mins i get this really annoying grinding noise, alot of noise when i am slowing down with the car still in gear, some grinding while idling , and No grinding with the clutch in..
so i am thinking i maybe jacked the bearings in the tranny when i misshifted? throwout? release? i am not sure what one... am i right?
what all could have gone wrong?
the egt went over 15k when the misshift happened and the rev's went well over 9k.
( yes i know i am an idiot )
setup:
95 gsx, 125k miles
fully moded:
t3/t4 turbo
550 injectors
hks 264/272
basically everything cept internals
35mm trial ewg
PLEASE HELP ,, WHAT's WRONG??
tj
setup:
95 gsx, 125k miles
fully moded:
t3/t4 turbo
550 injectors
hks 264/272
35mm trial ewg
tj
