21 - 33 of 33 Posts
Discussion Starter · #21 ·
NINJA7 said:
Do you need a head Nick?
I pretty sure that I will. Do you have a spare?? PM me with info please.
Discussion Starter · #23 ·
Tevenor said:
Duh. Nick always needs head, he just can't get any. :D
LMAO, Too funny!
Discussion Starter · #25 ·
Taboo said:
Which makes me wonder about Ninja's offer.. :D (J/K)
LOL!
Every valve on the head is bent really bad. Ill get a picture of it.
Discussion Starter · #26 ·
My valves
Ouch... Nick, you have the worst luck ever. As I remeber, you said you think your oil pump seized (which would explain the stripped teeth on the t-belt). You should definitely take the oil pan and the front case off since it's most likely the rear balance shaft spun the bearing and possibly also ate the block. The front case will most likely be damaged as well, so you'll need to replace the complete oil pump assembly (front case + oil pump gears + oil pump cover). When you're at it, yank the front shaft out as well and reverse the bearings so they cover the oil holes and eliminate both shafts. Don't worry about the block (if it's damaged by the balance shafts) and JB Weld the bearings to it. With the new oil pump assembly, used head, new t-belt, seals and gaskets, etc., you're looking at some 7-8 hundred bucks of investment.. I'll email you.
Discussion Starter · #29 ·
more pics
Here are the pistons:
another one of my head, see the rocker arms laying there?
Talk about bad news. I am sure he never wanted to hear that.
I think your best bet Nick is to buy a JDM engine and call it a day.
You are looking at more than $2500.00 to get the car functional again.:eek:
You might as well sell the car and start over dude...:(
Discussion Starter · #31 ·
Na, Ill just get it started and sell it.;)
OUCH!!! Nick, I am afraid that when I pull my motor, it will look just like yours!!!
I have some news for you about options as I have been researching what mine are... since we are in the same boat, I'll share them with you :) :santa:
I'll email you!
Whats up man, your in Sterling Hts too? This is what Im thinking happened:
Driving along, oil pump seized breaking off about 1 ft of timing belt teeth, the belt slipped on the crank and the pistons hit the valves. I don't have the head off yet because I cant find a damn 11mm allen hex head socket. But I will find out sooner or later.
Same problem. I found they don't have a 11mm. I thought that too, But 4g63 has 10mm.
21 - 33 of 33 Posts
