The NT trans has lower gear ratios. It's also weaker, so don't beat on it.
dstnbmx said:but there supposedly isnt any proof of this, all the turbo swap guys from n/t use the same tranny and just stage up the clutch........im lost i ruined my turbo tranny and have a n/t tranny clutch flywheel etc...ready to go in....
Sounds like you have other issues besides the transmission then. Check for boost leaks or a severely leaking wastegate. Also check your boost controller to make sure its running right. I'd pulled as much as 22psi out of it on race gas.dstnbmx said:how do you get 20 psi out of a 14 b? all i can get is 15-16
I killed the other trannys at closer to 15psidstnbmx said:yeah that sucks about your tranny. but i am not running the hp you are yet but when i get there i will just invest for a shep
Show me one post or one thread from someone who's done the swap or is running on an n/t reliably at any moderate power level and has had no problems. Sure you might find an old post or two of mine where I was blaming bad tranny's, or my driving, but in the end it was the weak tranny at fault every time.dstnbmx said:yes i realize you dont just order up a tranny from shepherd racing, you send yours in
yes i know the n/t tranny is weaker, although i did read that the n/t to turbo guys had no problems with it even with higher power levels. thats just what i read, i was only trying to figure out what was right because no i havent seen the insides of the two..
If you're going to use the nt transmission you may as well keep the boost extremely low and limp around on the nt clutch. It will hold very minimal boost. I'm trying to save you some money here. In the end you'll either be buying a new clutch and turbo tranny or end up constantly replacing the nt tranny's. If you don't have the money for the turbo setup now (btw, a local kid I'm helping just ordered the last fwd turbo engine backing plate in the country - sorry guys) then at least take it easy on the transmission and clutch so that you're not blowing your upgrade money trying to keep the weak things working to get you to your job and back. I tried to buy the fwd setup multiple times, but I went through the stock nt clutch, 3 nt tranny's, 2 cheap aftermarket clutches, and then onto the act before it became reliable enough (got a good tranny that held for a couple of months) and got a daily driver after it did break so that I could get the money around for the turbo setup. I'm trying to keep you from having the same headaches I did.dstnbmx said:all i am trying to do is use something that might not last forever until i can afford the better things...i see no problems with that and i dont appreciate your smart ass little comment...your an ass...this post isnt ripping me apart for my lack of dsm knowledge...i merely asked a question about things i had read before, checking other's opinions on it. and if my girlfriend wants to post a comment on here ladi fuckin da
