i need some help.
i sold my stock (98) infinity head unit to a friend with a 95/96 Talon. he also has the infinity head unit w/ amp but it is a different system than mine (no CD apparently) at any rate, it plugs right in, and he has the correct security code, but after entering the code nothing is happening.
i was wondering if any of you had attempted to put a '97/98 infinity system in place of your 95/96 version. and if so did you have any problems with the installation or operation?
i did some fairly extensive searching but most problems i found were code related. i need to know if the two are interchangeable. the buyer assumes there is some problem with the ECU/Stereo compatibility. i also read that you must hit the "tape" button to enter the code instead of just the 4 numbers. i cannot remember doing this when it was in my car, but its been awhile since i've used the radio.
i could really use a hand..........thanks guys.
much appreciation.
Brett
much appreciation.
Brett
