1 - 7 of 7 Posts
I've tried using the search, but after reading a shit load of threads I'm still asking the same question. I've just installed a 2g MAS with all honeycombs intact and find that I'm having a lot of trouble tunning the S-AFC. I'm running 550's, Walboro 255, 2g ported exhaust mani. and 1g ported o2. NE points are 1,000; 2,000; 3,000; 4,000; 5,000; 5,500; 6,000, 7,000. Throttle position settings are 25% and 75%. I can't get the dam thing to idle right (unfortunately no AFPR yet) and I get misses/shuddering when under load in 2nd. & 3rd. gear. EGT's are 1000-1500 under load boosting 15psi.
Can anyone with a similer setup give me their settings so I have somewhere to start?
Thanks
Thanks
What kind of intake tube are you using with the conversion...... A leak after the MAS and Before the turbo will give you trouble.
I have 550's, Walboro 255HP, 2g ported exhaust manifold, tubular o2, and a 16G turbo. Throttle position settings are 30% and 65%.
NE 1k - 2k - 3k - 4k - 4.5k - 5k - 6k - 7k
L +3 - +3 - +3 - +3 - +3 - +3 - +3 - +3
H +3 - +3 - +3 - +4 - +4 - +4 - +5 - +5
Everything works fine for me....
Running stock inlet pipe, but waiting on a new pipe for Dejon tool. I've got a big 16g ported and clipped. I'll try you settings. Anyone else.
Thanks
Just makesure there's no leaks..... what is your base fuel pressure at ?
Discussion Starter #5
Not sure, I'll have to check. What should it be??
38PSI..... that seems to be the average that I've gatherd.
(someone correct me if I'm wrong)
Discussion Starter #7
I think I'm at 40, but I'll check just to make sure.
1 - 7 of 7 Posts
