need some tranny help...
975 Views 1 Reply 2 Participants Last post by  dedlewamp
i am having trouble shifting between gears while driving. i have to rev match while pushing the clutch to get it into gear other wise the gears grind.. are there and cheaper fixes than taking it to a shop for trans work? i have bled the clutch and checked the transaxle fluid already. also when i step on the clutch to go to the next gear or slow down the motor bogs way down like there is a load on it?. any suggestions?. anyone had this problem before?
1999 Eclipse GST 5 speed
thanks
1 - 2 of 2 Posts
Check the adjustment of the clutch as shown and adjust as required. The proper procedure can be found on the VFAQ.
1 - 2 of 2 Posts
