Your cams and rockers will work as long as the head didn't take a major hit (with those numbers of bent valves I'd assume you're ok but w/out seeing not 100%). Check the lobes on the cams before re-installing.
However, the cam caps will not work. They're not interchangable between heads unless you find a shop that can bore them correctly, which isn't an easy task. We take head cores only if they have the original cam caps (order from head to head is the same, but they won't line up correctly for the cams to spin) because of this.
Curt
SlowboyRacing.com
Curt
SlowboyRacing.com
