So I have stock injectors 255 fuel pump and a aftermarket regulator its big turbo what should I have it set for idle and currently it at 48 psi and in wot 3rd gear I have like 11.5 for afr
Stock injectors and a big turbo are a bad idea. You will eventually blow your engine. The stock injectors can't flow enough fuel to support much more than stock boost. Big injectors and dsmlink are cheaper than a new engine.
To answer your question, I run 43psi fuel pressure at idle.
These cars are easy. Find someone with your same "big turbo" that is making power and copy their build. Unless your all about that blow it up and put it on jack stand life.
