Need to know where to get RPM signal from... Supposed to use the ground off a distributer. buuuuuuuttt.. ya know.
Rob
Rob
which one did you tap into (wire color if possible plz)? did go go directly to the ECU connector or somewhere else?You can use a test light to find out what wire had the signal for the RPM's thats what I did. Good luck
