1 - 2 of 2 Posts
I know there are plenty of issues like this on search, and I couldn't quite find my problem. I'm also at work, and barely made it here and need to get home.
I just replaced my slave cylinder (I thought this was the issue), and my master isn't leaking. I have an act 2600 6 puck (not new). I put a spacer behind the pivot ball.
Problem: My car will not go into gear while driving. It occasionally ranges from hard to get in, to grinding, then to what just happened, won't go in to gear while on. My clutch is adjusted, It's been running fine for the past 800 miles.
I have no idea, If my fork was bent wouldn't I not be able to shift while off? Or same if it was stretched cables.
1 - 2 of 2 Posts
