Yea, you probably wouldn't find my thread, cause it was quite awhile ago but i'm just now getting my stuff together to get it fixed. Otherwise, i'm just having my g/f drive me around in her 96hp Kia Rio
!!! Either way, the first thing i replaced was the PCV valve, original dipstick still popped out about 1/2" but then more and more if i drove it with out putting it back in. Ordered a new dipstick and finally got it and put it in. Definately a tighter fit, but still pops out about 1/4" and lets oil out. I replaced the turbo with a big16g and replaced all oil and water lines (brand new) to the turbo (send lines and return lines) so i'm not sure what the deal is.....
My idle is kinda funky too, not as bad as some of the idle surge stories i've heard, but maybe my ECU capacitors are leaking, so that'll be the next thing i'll take a look at. I've already tested the ISC and looked to see if my BISS screw is still there and it is......
My boost comes very quickly, i hit full boost at about 3500 (stock boost) hallman MBC should be here in 1 more day!
Could my stock cat be clogged and it's backing up pressure through the head and creating more positive crankcase pressure than the PCV valve can let out and therefore making my dipstick pop out??? I'm going on theories here because i don't wanna believe that this engine has blown rings too. that'll be 2 cars i have to replace rings/rebuild an engine on
but why should i be crying to you guys? I'm sure you guys have heard it all on trying to supe up 2 cars at the same time.....it's extremely hard while working and going to college. Well, either way, hit me back and tell me what ya'll think......
