First of all I have a fran oil filter and thinking about returning it for the mitsu OEM filter. Someone else mentioned that the Mitsu OEM filter is the same as a WIX filter with the Mitsu name on it. Anyone know the part # for this WIX filter for a 99 GS-T?
Second my car is idel at 1000 when I first start it up then after I drive around for a while it tends to idel at around 500-very low 600 RMP. Is this to low?
Well it's half way between the first mark and 1K so I believe it's around 500-600 max. When I first fire it up it idels at 1K for awhile then drops down to 500-600. No it sounds fine. Seems like I gotta give it a little more gas and I'm a little slow to get going though.
like I said are you reading it right, that sounds like its idels at around 750.
the 1st mark is zero, then 500 mark, then 6,7,8,9, and 1000
yes when its cold it idles higher until it warms up.normal
