I considered the fact that maybe the drain hole got clogged with RTV, so I bent up a paper clip and it went through no problem, so I dont think it was clogged, then I dug through my storage parts (Im getting more than I want) and found the nasty looking factory oil pump from the block that I bought awhile ago, its a factory Mitsu frontcase/oil pump, the drain hole looks slightly larger on there compared to the new cheap-o advanced auto one that I have on my car. Thats when I started to think about possibly drilling it out just a hair, like one drill size bigger, it cant hurt anything as long as I clean it good. I'll probably experiment with the old Mitsu one I got for free because its garbage anyways.
Im fairly certain its leaking from the oil pump seal because today when I pulled it apart as soon as I pulled the oil pump sprocket off I could see alittle oil sitting inside the sprocket, and it looked clean around that plug just above/behind the oil pump sprocket, also in the last ~150 miles its leaked maybe a tablespoon or 2, so its not like its just pouring out somewhere, but the fact that the timing belt is right there, and Ive got 16 new SS valves because the oil leak already cause my belt to slip (it leaked worse then but still) last fall, I need to fix this before I can really drive it too much.
Thanks for all the suggestions....Now Ive at least got a couple things I can try, I'll start with adjusting the spring inside the oil pump seal, I'll know on Wednesday if that helped. Otherwise everything is coming off and Im gonna do a little machine work on it, and I might try thinner oil, low pressure isnt going to be a problem with no B-shafts and no squirters.
