Nevermind I figured it out.
How exactly do the marks line up. There are two gears, one small, one larger. They both have a timing mark in the center of one gear tooth. When I line up the timing marks, should the mark on the larger gear be on the right or left of the marked tooth on the smaller gear?ginsu said:If you do disassemble your oil pump, just line up the marks on the gears when you reassemble it.
