1 - 20 of 345 Posts
The new method to submit your times is as follows:
Click on "Quick Links"
Click on "Timeslips"
Add your car to the profile, and upload your run information, a timeslip image can be added for verification if needed.
Old Unsupported Method:
Hey guys. Welcome to the DSMtalk track times submit area.
You may have noticed the stickies we've started in Racing, it's a general way to list the times of DSMtalk members. We really need your help here guys, so try to submit your times and mods without a lot of discussion and this will all work out. You can discuss mods and times in existing threads, PM's, or new threads....
TO SUBMIT A TIME OR UPDATE TO THE LIST:
There are two ways to do it to start this off, we'll see if it works out or not. We really need your help and co-operation with this. It's a huge job and we have full time jobs and a full time lives, so be patient and we'll try to keep this all running smoothly. :D
Ways to submit:
1: Post your times and modifications in this thread. Please, keep discussion to a minimum. If it gets out of hand, we'll close it and just use the PM feature.
or
2: Send me a PM with your mods and times. Remember that I'm sure to get swamped at times, so be patient and everything will work out.
Some things to remember to list when submitting times:
-awd or fwd?
-boost pressure
-race or pump gas
-open exhaust?
-weight reduction?
-track elevation?
-other modifications
-and of course, what kind of turbo is it?
Thanks, and enjoy!
-DSMtalk moderators
DSMTalk FinePrint: The track times area is for DSMtalk members only, and is not meant to replace the http://times.dsm.org site. Also, we cannot verify the accuracy any times submitted. Times are submitted in "good faith"...we hope DSMtalkers will be honest and truthful...thanks for your help.
Discussion Starter #2
Sample Entry:
[email protected] 1.89 60'
99GSX awd
Mods:
Mutt Level 1 turbo at 22psi
100 octane
Ported o2, 3" turbo back, high flow cat
625cc injectors, S-afc. 255 fuel pump
NGK 7es plugs
Spare tire and tools removed, headlight removed.
16" rims.....blah blah blah you get the point
Well, you get the idea....this area is not only to help me post your times, it is also a place where people can look first for information about your time.
-Jon
I saw my name was alreay on the list, thats cool. Here is a list of mods, and condition's the run was made in, that are not on the list, for there are no ? marks.
Cam 2 Fuel
22psi
hacked maf
2.5 pressbent exaust, no cat
Fathouse
BTW, very good idea on making a list. :)
FP T28/28
1997 Tsi Awd
Forced Performance T28/28
Pump gas
No cat
FMIC
SuperAFC
Stock tires
London Dragway @ sea level
[email protected]
DG
(I gotta do a pass with the current setup - that time is OLD)
Times update
90 GSX
small 16g internal gate
3" exhaust (pressbent)
vpc/afc
550cc
supra pump
track: Rockingham, N.C.
(no tach,=not a great 60' and misshifted 3rd badly)
1.79 60'
[email protected]
This was the first and only time to track with that setup.
Richie
[email protected] mph 1.9 60'
91 Tsi awd
Mods:
Buschur Racing Br-57 @19 lbs of boost
94 Octane
Buschur 3in exhaust w/straight pipe and tial 35mm wastegate
650 injectors hacked mass aem fpr, s-afc
91 rod 95 piston motor, stage II head porting oversized valve springs, web street cams street grind
Denso W 20exr-u plugs
17x7.5 in rota rims 245 40 Kuhmos
Maple Grove @ 550ft above
[email protected]
'95 Talon AWD
-Full weight, even the spare tire, Minus A/C
-Buschur built 2.3L Stroker.
-Buschur BR-57 turbo.
-T3 manifold w/ Deltagate.
-Sheetmetal Intake.
-HK$ 272 Camshafts.
-HK$ VPC & GCC.
-BLA BLA BLA....
1998 GSX
98 GSX:
-TRE Small 16G
-TRE O2 Housing
-TRE Exhaust Manifold
-GReddy Small FMIC
-GReddy I/C Pipes
-1G BOV
-Old-Style APEX'i AFC
-Walboro 255 Fuel Pump
-APEX'i 3.00" Exhaust
-RS*R 2.50-3.00" Downpipe
22psi - C16
12.509 @ 113.7MPH - Rockingham Dragway
93 AWD
25psi
50/50 mix of 92 octane pump and 110 octane leaded (~101otc.)
2.5 mandrel dp w/ 3 catback
3200lbs w/ driver
1000?ft Joiliet, IL
FP T3/T4 turbo
stock 128k mile 7 bolt
Haltech E6k
1000cc injectors
...lots of other misc shit
-only 2 pulls to tune the standalone form scratch
-AEM bypass valve went through the turbo and a large portion of the compressor wheel was gone
still ran
11.70 @ 117.7mph
blowing off an intecooler pipe in 4th
Mike Clark
13.282 @ 101.39mph, 60ft 1.742, 17psi
93TSI AWD
Mods:
BR UICP
BR 2.5press bent exh
BR DP
BR cat
EVO III o2 unported
K&N
welded Diff.
93pump+110oct
Act2600+st disk
Elevation ~1250ft
Removed jack/spare
Everthing else stock!
1 - 20 of 345 Posts
