From the one pic in you sig, I could not see a FMIC. So air blockage probably is not the problem. I would think the timing belt would be unrelated to a temp problem but I don't know for sure. This may be a dumb question, but are you sure it is actually overheating? Have you taken the temp of the radiator? Your problem is just the opposite of a normal over temp problem. Normally, it is in slow moving traffic that cars overheat. Your problem is at when the car should just be [email protected] mph.
The only suggestion I have is a Fluideyne radiator but I think that would be a band aide to a larger problem.
