1 - 14 of 14 Posts
Whats up guys? My car had a cracked thermostat housing, and would leak coolant untill it was almost empty. Then throw the rest in the overflow. I just replaced the thermostat and housing, and there are no leaks, but about 15 min's of driving, it starts to over heat. If i let it run without the cap, the thermostat opens, and collant flows very nicely. I tried adding coolant while the thermo was open, but it doesn't take much before it starts to overflow, and i know the radiator isnt full. Could this be a radiator clog? Also, the overflow does not have a cap, just a line running into it. Would this cause it? When i stop the car, and shut it off, even at normal temps, the top radiator hose is solid, and you can hear air leaking from the hoses and cap, due to over pressure. Car has been down for many months, this is the last thing to tackle. Please help. thanks
Also make sure you have correctly burped the system..
Here is a check list for you.
After countless attempts to help disseminate the correct way to troubleshoot overheating issues i've finally decided to write an article about it.
Note: if nothing on this list fixes your overheating problem, sell your car. It's possessed and only god can help it now.
So you're overheating. Maybe it's only when you turn your A/C on. Maybe it's only when sitting in traffic. Did you install a FMIC and all of a sudden your car is sweltering?
Read through the list. Of course not everything may apply to you, so address the issue accordingly.
Replace your thermostat. Try a 180° F Mitsubishi thermostat. It is part number MD997607.
Your radiator cap might be old, and leaking too easily. Try a 16 lb radiator cap from a Nissan 300Z TT. Watch out - you might blow old heater or coolant hoses with the higher pressure, so be careful, or replace your hoses beforehand.
Your fans might not be running. Replace the fan temperature switch at the bottom of the radiator.
Low coolant levels. Top up your overflow bottle. There should always be coolant in the bottle. If your system is perpetually low on coolant, your bottle isn't big enough.
Your overflow bottle is not allowing coolant back in. Check the overflow bottle still has a
hose leading to the bottom of the bottle. The system must be able to draw coolant back in.
Flush your radiator. Old coolant (or a clogged radiator) could be the problem.
Try adding some Water Wetter or RMI-25 to aid cooling. Note that some of these products promote corrosion to a small degree.
Try a 90/10 to 70/30 water/antifreeze mix. More water leads to more cooling, but easier freezing and more corrosion.
Try running with no thermostat. If you still overheat, the problem is probably not in your cooling system per se; probably your difficulty is airflow through the radiator. (TEMPORARY TROUBLESHOOTING TECHNIQUE. Do not keep the thermostat out of the car to fix your problem...)
Wire both fans to run simultaneously. Obviously this only works if you have an secondary (air conditioning) fan to hotwire.
Run both fans permanently. That is, wire them to be always on. Note that the driver's side of the radiator probably doesn't cool as much as passenger side, because of where the radiator inlet and outlet are placed.
Remove the rear hood weatherstripping. Or, shim the rear hood hinges to raise the rear hood edge about 1/4-1/2". This promotes airflow out of the engine bay.
Install better fans. There are "high-performance" models available - get the ones with the best airflow.
Try shrouded fans instead of unshrouded fans. Shrouded fans seem to cool better.
Install some ducting to force incoming air into radiator. This mostly works only if you are having problems only when driving at highway speeds.
Install some high-temperature weatherstripping on top of radiator to try and force more air through it.
Open up front bumper fascia to allow more air flow to radiator.
Replace or upgrade the radiator. Fluidyne and Arizona Performance make upgrade models. You can try to get your radiator cleaned (or "rodded out") if you want to.
Install an external oil cooler to try and lose some heat that way. Leave a gap between the oil cooler and the radiator, if possible.
Wrap the water pipe near the turbo with heat wrap or jet hot/ceramic coat it.
If you have the air conditioning still in, remove the A/C condensor.
Maybe the water pump belt is slipping.
Install a new water pump.
Check your crankshaft pulley has not separated.
Check that your A/C refrigerant level is correct. Only applies if the A/C causes the overheating.
If all else fails, maybe a leaking headgasket is the problem. Run a compression test. Don't forget about the torque specs for the head bolts/studs also. Sometimes a simple torque wrench can fix your problem.
Special thanks to www.vfaq.com
Discussion Starter · #5 ·
compression is 155 155 155 153. Oil looks ok, coolant doesnt have oil in it. No it hasnt over heated,soon as it hits the second line one the coolant symbol, i shut her off, not even close to being in red. I think it needs a burp
I bet your right, burp that bitch.:D
Do you have DSMLink? IF so, another safety feature is to set your check engine line to come on at 220 degrees to give you a 16 degree safety margin.
Site Administrator
Temp sensor reads coolant temp in the thermostat housing. It's not a perfect system the motor can be dry but the thermostat housing still read normal temps.
Other side to this is the temp sensor does not read the temp of steam, if the housing is dry it will not show overheating either.
I used RTV high temp on my water pump and thermo housing... Had a running hot problem to. I had a 2inch piece of RTV stuck in the banjo fitting the goes into the front of the block behind the turbo(7bolt?). nothing in the other one though.
Thanks
I've seen people on this forum who had good compression numbers, and a bad HG. Also, you can blow a HG without bridging coolant and oil passages. Sometimes when a HG goes, the coolant or oil passage just gets bridged with the combustion chamber only, and you then burn whichever leaks in....don't always rely on oil in coolant or coolant in oil to determine if you need a head gasket.:rolleyes:
Discussion Starter · #14 ·
Yea, i know, thats why im doing a leak down test. The car has been through 2 turbo's, each one had no shaft play, but bad seals. I thought the pcv was bad, but headgasket would make sence
1 - 14 of 14 Posts
