Ok ill start from the beging so you know what iv done and havnt. I had gabor put his clutch in.. he told me the master cylinder was bad, and to replace it. So a few weeks later i did. well about a month, never had the time. So last night i rebuilt it, and bleed the system. Today the clutch pedal engagment point change alot, moved all the way to the top, if i pressed on the gas and got into boost it would slip, and you could not push the clutch tot he floor due to it being out so far. Well i just thought i didnt tighten the locking bolt tight enough on the ckutch ajusment thingy. So i went home fixed the engagment point and tightened the bolt. Back out of the garage and when i put it into 1st to go up the street.. the engagment point changed alot, almost to were it was before when the clutch was slipping but it does not this time. Also when i was backing out of the garage, the check engine light came on. So i went to Autozone and got the code.. and its a p1400 DPFE EGR curcuit low input. I did notice some fluid around the master cylinder, by the metal line that goes to the slave so maybe i didnt tighten that enough. ALso i have a new ISC (gabors) and i have a new EGR vavle.
So my questions what would cause this? How to fix it? What is wrong with my car?
thanks for anyhelp
kyle
thanks for anyhelp
kyle
