P1105 O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+ A
P1500 Fuel Pump Relay Circuit - Electrical Malfunction A
1105 is for your post cayt O2 sensor. 1500 is obviously for your FP relay. With 1105 normally an o2 sensor code means the sensor is bad but let the car run (idleing) and move all the wiring for that sensor around and have someone else watch your o2 readings for that sensor to see if they fluctuate (all the way high or low)
Same deal on your 1500 code. Check your connections at the relay and the wiring, use a voltmeter (test light might work if you don't have a voltmeter) and see if you loose power or ground while your moving the wiring around and smack the relay a couple of times too.
If you don't want to do all of that then you could do what real mechanics do and just replace the o2 sensor and the relay and see if it fixes your problem.
