Here is it, tell me what you think i should be doing or what something should read and what would need done to correct. this. 92 Talon, 6 bolt from a 90. 13psi. 190lph (from what previous owner said) 3in exhaust.
TIMA,COOL,FTRL,FTRM,FTRH,FTO2,EGRT,O2-R,BATT,BARO,ISC,TPS,MAFS,ACLE,ERPM,KNCK,INJP,---,AIRT,O2-F,,CUS0,CUS1,CUS2,CUS3,CUS4,CUS5,CUS6,CUS7
29.00º,61.00ºC,138.84%,99.06%,81.12%,,296.28ºC,0.88V,14.22V,0.96bar,228.00,27.45%,408.85Hz,,2593.75rpm,0.00,4.35ms,130.00,17.31ºC,0.99V,,,,,,,,,
30.00º,61.00ºC,138.84%,99.06%,81.12%,,290.28ºC,0.90V,14.22V,0.96bar,228.00,32.55%,459.17Hz,,2656.25rpm,0.00,5.89ms,2.00,17.31ºC,1.40V,,,,,,,,,
25.00º,61.00ºC,138.84%,99.06%,81.12%,,279.78ºC,0.23V,14.15V,0.96bar,228.00,44.31%,515.78Hz,,2750.00rpm,0.00,7.94ms,131.00,17.31ºC,1.81V,,,,,,,,,
19.00º,61.00ºC,138.84%,99.06%,81.12%,,249.78ºC,0.94V,14.15V,0.96bar,228.00,56.47%,559.81Hz,,2875.00rpm,0.00,14.08ms,129.00,17.31ºC,2.36V,,,,,,,,,
13.00º,61.00ºC,138.84%,99.06%,81.12%,,230.28ºC,0.96V,14.07V,0.96bar,228.00,60.39%,572.39Hz,,3062.50rpm,0.00,17.41ms,129.00,17.31ºC,2.94V,,,,,,,,,
12.00º,61.00ºC,138.84%,99.06%,81.12%,,212.28ºC,0.96V,14.07V,0.96bar,228.00,66.27%,591.26Hz,,3218.75rpm,0.00,19.97ms,129.00,17.31ºC,3.69V,,,,,,,,,
8.00º,61.00ºC,138.84%,99.06%,81.12%,,198.78ºC,0.96V,14.00V,0.96bar,228.00,70.59%,610.13Hz,,3468.75rpm,21.00,20.99ms,129.00,17.31ºC,3.96V,,,,,,,,,
5.00º,61.75ºC,138.84%,99.06%,81.12%,,194.28ºC,0.97V,13.93V,0.96bar,228.00,76.86%,616.42Hz,,3656.25rpm,21.00,20.48ms,129.00,17.31ºC,4.19V,,,,,,,,,
8.00º,61.75ºC,138.84%,99.06%,81.12%,,183.78ºC,0.97V,13.93V,0.96bar,228.00,83.14%,616.42Hz,,3906.25rpm,20.00,20.99ms,129.00,17.31ºC,4.54V,,,,,,,,,
9.00º,61.75ºC,138.84%,99.06%,81.12%,,171.78ºC,0.96V,13.85V,0.96bar,228.00,100.00%,616.42Hz,,4156.25rpm,19.00,21.50ms,129.00,17.31ºC,4.84V,,,,,,,,,
9.00º,61.75ºC,138.84%,99.06%,81.12%,,155.28ºC,0.97V,13.85V,0.96bar,228.00,100.00%,616.42Hz,,4375.00rpm,20.00,22.78ms,129.00,17.31ºC,4.97V,,,,,,,,,
9.00º,61.75ºC,138.84%,99.06%,81.12%,,147.78ºC,0.97V,13.85V,0.96bar,228.00,100.00%,616.42Hz,,4531.25rpm,19.00,23.04ms,129.00,17.75ºC,4.97V,,,,,,,,,
9.00º,61.75ºC,138.84%,99.06%,81.12%,,135.78ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,4781.25rpm,18.00,23.30ms,129.00,17.75ºC,4.97V,,,,,,,,,
10.00º,61.75ºC,138.84%,99.06%,81.12%,,137.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,4812.50rpm,18.00,23.04ms,129.00,17.75ºC,4.97V,,,,,,,,,
11.00º,62.50ºC,138.84%,99.06%,81.12%,,131.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5031.25rpm,18.00,22.78ms,129.00,17.75ºC,4.97V,,,,,,,,,
10.00º,62.50ºC,138.84%,99.06%,81.12%,,125.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5125.00rpm,17.00,23.04ms,129.00,17.75ºC,4.97V,,,,,,,,,
13.00º,62.50ºC,138.84%,99.06%,81.12%,,120.78ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5250.00rpm,17.00,23.04ms,129.00,17.75ºC,4.97V,,,,,,,,,
13.00º,62.50ºC,138.84%,99.06%,81.12%,,120.78ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5437.50rpm,16.00,22.27ms,129.00,17.75ºC,4.97V,,,,,,,,,
13.00º,62.50ºC,138.84%,99.06%,81.12%,,116.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5562.50rpm,15.00,22.27ms,129.00,17.75ºC,4.97V,,,,,,,,,
14.00º,62.50ºC,138.84%,99.06%,81.12%,,116.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5718.75rpm,15.00,21.76ms,129.00,17.31ºC,4.97V,,,,,,,,,
15.00º,63.25ºC,138.84%,99.06%,81.12%,,111.78ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5843.75rpm,14.00,21.76ms,129.00,17.31ºC,4.97V,,,,,,,,,
15.00º,63.25ºC,138.84%,99.06%,81.12%,,113.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5906.25rpm,14.00,21.25ms,129.00,17.31ºC,4.97V,,,,,,,,,
16.00º,63.25ºC,138.84%,99.06%,81.12%,,117.78ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,5937.50rpm,14.00,20.74ms,129.00,17.31ºC,4.97V,,,,,,,,,
16.00º,63.25ºC,138.84%,99.06%,81.12%,,113.28ºC,0.97V,13.78V,0.96bar,228.00,100.00%,616.42Hz,,6062.50rpm,13.00,20.74ms,129.00,17.31ºC,4.97V,,,,,,,,,
16.00º,63.25ºC,138.84%,99.06%,81.12%,,107.28ºC,0.97V,13.78V,0.96bar,228.00,99.61%,616.42Hz,,6312.50rpm,14.00,20.48ms,129.00,17.31ºC,4.97V,,,,,,,,,
15.00º,63.25ºC,138.84%,99.06%,81.12%,,113.28ºC,0.97V,13.78V,0.96bar,228.00,98.82%,616.42Hz,,6312.50rpm,13.00,19.97ms,129.00,17.31ºC,4.97V,,,,,,,,,
