Please look at my log....
504 Views 1 Reply 2 Participants Last post by  thegreatms
Tel me what you think, car is 6bolt with 91 oct. 14B, 190lph, halman MBC shuld be at 11 or 12psi. apexi DP with thermal catless catback. also have a K&N.
I adjusted the timing however i dont have a timing light. Im at around 11-12psi. 91 octane. mods in profile. Some may have seen my last post with my last log. Had ALOT of knock ect.. refer to that if need be. I also hooked up the ground wire to the downpipe.
What do you think now?
TIMA ,FTO2 ,TPS ERPM, KNCK,
29.00º,,,,,,,0.82V,,,, 29.02%,,,2531.25rpm, 1.00
28.00º,,,,,,,0.80V,,,, 29.41%,,,2531.25rpm, 1.00
29.00º,,,,,,,0.21V,,,, 29.41%,,,2531.25rpm, 0.00
29.00º,,,,,,,0.35V,,,, 43.14%,,,2593.75rpm, 0.00
25.00º,,,,,,,0.82V,,,, 61.18%,,,2625.00rpm, 0.00
20.00º,,,,,,,0.92V,,,, 72.94%,,,2656.25rpm, 0.00
18.00º,,,,,,,0.96V,,,, 87.45%,,,2718.75rpm, 0.00
16.00º,,,,,,,0.97V,,,, 96.08%,,,2781.25rpm, 0.00
14.00º,,,,,,,0.97V,,,, 99.22%,,,2812.50rpm, 0.00
13.00º,,,,,,,0.97V,,,,100.00%,,,2875.00rpm, 0.00
13.00º,,,,,,,0.97V,,,,100.00%,,,2937.50rpm, 0.00
12.00º,,,,,,,0.97V,,,,100.00%,,,2968.75rpm, 0.00
12.00º,,,,,,,0.97V,,,,100.00%,,,3062.50rpm, 0.00
12.00º,,,,,,,0.97V,,,,100.00%,,,3156.25rpm, 0.00
13.00º,,,,,,,0.97V,,,,100.00%,,,3218.75rpm, 0.00
13.00º,,,,,,,0.97V,,,,100.00%,,,3312.50rpm, 0.00
14.00º,,,,,,,0.97V,,,,100.00%,,,3343.75rpm, 0.00
14.00º,,,,,,,0.97V,,,,100.00%,,,3437.50rpm, 0.00
14.00º,,,,,,,0.97V,,,,100.00%,,,3531.25rpm, 0.00
15.00º,,,,,,,0.97V,,,,100.00%,,,3625.00rpm, 0.00
15.00º,,,,,,,0.97V,,,,100.00%,,,3656.25rpm, 0.00
15.00º,,,,,,,0.97V,,,,100.00%,,,3718.75rpm, 0.00
16.00º,,,,,,,0.97V,,,,100.00%,,,3781.25rpm, 0.00
16.00º,,,,,,,0.97V,,,,100.00%,,,3875.00rpm, 0.00
16.00º,,,,,,,0.97V,,,,100.00%,,,3968.75rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4031.25rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4093.75rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4156.25rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4250.00rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4281.25rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4406.25rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4437.50rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4468.75rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4562.50rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4593.75rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4625.00rpm, 0.00
17.00º,,,,,,,0.97V,,,,100.00%,,,4718.75rpm, 0.00
18.00º,,,,,,,0.97V,,,,100.00%,,,4812.50rpm, 0.00
18.00º,,,,,,,0.97V,,,,100.00%,,,4781.25rpm, 0.00
18.00º,,,,,,,0.97V,,,,100.00%,,,4843.75rpm, 0.00
18.00º,,,,,,,0.97V,,,,100.00%,,,4875.00rpm, 1.00
17.00º,,,,,,,0.97V,,,,100.00%,,,5000.00rpm, 1.00
17.00º,,,,,,,0.97V,,,,100.00%,,,5156.25rpm, 1.00
18.00º,,,,,,,0.97V,,,,100.00%,,,5187.50rpm, 0.00
18.00º,,,,,,,0.97V,,,,100.00%,,,5093.75rpm, 0.00
20.00º,,,,,,,0.97V,,,,100.00%,,,5125.00rpm, 0.00
20.00º,,,,,,,0.97V,,,,100.00%,,,5312.50rpm, 0.00
20.00º,,,,,,,0.97V,,,,100.00%,,,5187.50rpm, 1.00
20.00º,,,,,,,0.97V,,,,100.00%,,,5312.50rpm, 1.00
20.00º,,,,,,,0.97V,,,,100.00%,,,5375.00rpm, 1.00
21.00º,,,,,,,0.97V,,,,100.00%,,,5406.25rpm, 1.00
21.00º,,,,,,,0.97V,,,,100.00%,,,5500.00rpm, 0.00
20.00º,,,,,,,0.97V,,,,100.00%,,,5531.25rpm, 0.00
22.00º,,,,,,,0.97V,,,,100.00%,,,5500.00rpm, 0.00
21.00º,,,,,,,0.97V,,,,100.00%,,,5593.75rpm, 0.00
21.00º,,,,,,,0.97V,,,,100.00%,,,5687.50rpm, 0.00
22.00º,,,,,,,0.97V,,,,100.00%,,,5687.50rpm, 0.00
21.00º,,,,,,,0.97V,,,,100.00%,,,5656.25rpm, 0.00
21.00º,,,,,,,0.97V,,,,100.00%,,,5625.00rpm, 0.00
22.00º,,,,,,,0.97V,,,,100.00%,,,5750.00rpm, 0.00
1 - 2 of 2 Posts
Looks good, you got no knock. I would turn up the boost a bit. Then make another run.
1 - 2 of 2 Posts
