1 - 10 of 10 Posts
Is it possible to remove the power steering from a 1G Eclipse? and if it is are there any places/ or people that can help me remove it in Kentucky(Louisville)? Plus jus wantin to see who all from KY is on here...:D
what were you hoping to accomplish by doing so?
Helping to reduce weight(also wanna remove the a/)c too, less hassle of having to replace that belt since the pulley is damaged anyways..
Discussion Starter #4
Helping to reduce weight(also wanna remove the a/c too), less hassle of having to replace that belt since the pulley is damaged anyways and its gonna need to be replaced and that might end up being pretty expensive too...
yes it can be done.
just find a 2.0 or 1.8 that dosnt have power streering and use their steering system.
I know there are a few guys on here that have done it before.
Are there any people on here that work at Buscher Racing? I know kevein did it to his 603whp Talan.
Discussion Starter #6
Thanks GST..atleast I know it can be done now.. another question when if I took out the p.s. would I have to goto rack and pinion?(semi new to the dsm's) .. also y in the world did it post me twice when I edited it
Removing power steering and ac helps free up some lost horsepower since those luxuries are a parasitic drag on the engine. Let me know how hard it was to replace your pulleys with the new ones. Also if it was worth it
Discussion Starter #9
Hell yea..thanks alot.. peace
A search would turn up some more information.
You don't need to replace the rack. I removed the pump and all the lines, then looped the in & out on the rack together. Leave a little fluid in it!
It's kinda' rough at <5mph, but after that it's fine. A manual rack will make it a little easier to turn.
1 - 10 of 10 Posts
