1 - 9 of 9 Posts
Ok, my ecu took a shit a while back, so got another one from the boneyard, but it was '93 ecu, so i switched the wires as per the vfaq, and it seems to run ok, except for 2 things, one, it has idle surge, but only when coming to a stop, if you have been stopped for a while it idles normal. second thing is that if you press the throttle more that about 1/4 throttle the tach starts to bounce around, decreasing eventually to zero when you get to WOT. My question is that the 90's have a different power transistor correct? if so, could that cause these problems, other than the idle surge and the screwed up tach it runs great. Thank you.
tsk tsk tsk, TRIPPLE post, mods aren't gonna like you for that:realmad: :crackit:
Discussion Starter #6
come on guys i really need your help here, i am driving it back/forth to school and it makes me and my car look really bad when i'm sitting at the stop sign and it sounds like i'm revving on every car in the other lane. Please help, thanks, Sean
Have you tested your ISC motor? I know those like to go out
Discussion Starter #8
well, I checked the isc before i changed the ecu, and it was fine, but i will check it again, but that wouldent alter the tach would it?:dunno:
Discussion Starter #9
ok, finally got around to checking the isc motor again, and i think it bit the dust since the top two pins register infinite resistance, so i'm pretty sure thats why it idles wierd, but i also would like to know what is up with my tach, who here has converted 90 to 91-94 ecu, did it do this for you, the tach never bounced like this before, please help.:( :(
1 - 9 of 9 Posts
