1 - 15 of 15 Posts
So, I finally got those old rusted bolts off and installed my new Tokico Illumina's and Eibach Pro Kit. I thought everything was okay, but after driving around the block there were alot of noises coming from the struts. I looked back to the rear and noticed the struts were sticking all the way up. I got back home and looked and noticed that the struts were all sticking out. It was soo bad that my front right strut popped out and made a dent on the hood.
Soooo, I'm sure I didn't install something that was needed.
Here is my scenario. I'm install my new Tokico Struts with Eibach Pro Kit on a car that had stock struts with MaxSpeed Coilover springs. I thought I was just missing the rubber spring seat, which I did buy, but I'm assuming I'm missing other things too. All I have are rubber bushings under the strut mounts.
Is there suppose to be another metal peice under the strut mount somewhere? Can someone post a real pic of all necessary parts and in which order they go on? If I have some time I will post pics of all the parts and which order I put them in to show you all.
Damn!!! This project is starting to suck. It took me forever to get some bolts off too!!!
Damn dude I no how you feel. My driver side was a PITA... I couldnt even get the bottom screw out at all from the lower control arm. But, I did this like a day ago. Let me see what I can rember.
1.Strut
2.Spring
3.Yellow (or w.e color) bushing like a stopper goes on the strut towards the top
4.Dust cover
5.Rubber piece with a metal cylinder in the middle of it
6.The rubber where the spring sits on
7.The metal bracket with the 3 screws
8.Another rubber type of thing goes in the middle of the metal bracket
9.A small metal like a washer thing
10.Then the final screw that screws everything together at the top
That is the order I belive from bottom to top, if you still dont get it pm me or somehting I'll see if I can help.
Picture going up on Body Tech Forum (check my springs ans shocks out on there)
Discussion Starter · #4 ·
1.Strut
2.Spring
4.Dust cover
That sounds like what I did too. On step 5, the only metal peice I had aside from the washer thing on top was the 2 inch long cylinder where the rubber bushings on the bottom and top of the strut mount fitted on.
#8 you, does that rubber actually fit inside of the hole of the strut mount or does it just sit on top?
Aside from the spring seat, I only had one rubber bushing under the strut mount and one over the strut mount; but not one fitted in the middle of the strut mount. I think my rubber bushing that I put under the strut mount has a ring cut-out around it.
I need to get some real pictures to see what I'm doing wrong. I have drawing diagrams of the parts, but that just isn't helping.
Discussion Starter · #5 · (Edited)
Here goes some pictures:
This first pic you can see how the strut popped up. This is the front passenger side.
In this second picture you can see the parts that I have. This is the rear passenger side.
That's all that I have. So what's missing???
LMAO.... This reminds me of when I installed my tokico blues... I was like WTF? I fixed that by putting some washers that are big enough that wont go though the hole and hold the shock in place...
Discussion Starter · #8 ·
I was thinking about putting in some washers too, but I wasn't sure if that would be proper.
Skywise's link took me to some suspension diagrams and I think I found what I'm missing. I think it's the "Cup Assembly". I'm assuming this is a metal "cup" looking like thing, but I guess a strong washer would probably work too.
Any suggestions would be great! Would a washer about the size of the top washer work?
Discussion Starter · #9 ·
On the struts there are two parts that the washer or the cup can sit on. A smaller one above and right below a larger one. With the washers that you used... did it sit on the smaller one or the larger one? How many washers did you use for each strut?
I don't recall... I just used one thick washer per shock... my rear ones didn't require washers.... ;)
Discussion Starter · #11 ·
Well, I ended up putting two washers into each strut in place of the "cup". Hopefully this holds. I bolted everything back into place and it seems like it's working ok. No strange noises and the struts haven't popped out yet.
I had the same issue. You need 2 washers per side. If you don't have a bottom one on there, the strut rod will push up through the bushing. If you don't have a top one on there you can't tighten down the rod nut properly. I think you've got her fixed now.
Discussion Starter · #13 ·
I hope so! I haven't had a chance to drive it around yet, so hopefully it's ok.
Yes, you will be ok, I remember when my strut went up like that, I freaked out at first and then got pissed because that meant I had to do it all over again... and the front ones are a bitch!... at least on my old 2g...But congrats man and I hope your washers don't take a shit on you :p
Discussion Starter · #15 ·
Thanks man! I hope it's all good too.
1 - 15 of 15 Posts
