1 - 6 of 6 Posts
Hello all!
I just purchased a 92 Laser AWD. It has some uhhh PROBLEMS, but I hope I can get it to hold together long enough to retire my current autocross car and run this one next season. So far this is the bad...
Smokes on startup
Exhaust has no muffler from cat back. I wonder if this hurts power?
Oil Guage does not funtion
Noise like the lifters are clicking
Tires are of all different makes and tread deapths
Passenger window barely goes up
Liftgate wont stay open and fuel door has to be pryed open
Previous owner says it is way out of alignment. I hope it's not more because on smooth roads it's fine, on bumps it is almost undrivable above 55 because it darts and kicks threw the steering wheel.
Good Points
Turbo seems to be tight
I like the color.
umm thats a lot of probs
i think the lifter tick just happens live with it.. think theres a way to lessen it they can help
exahust wont really hurt, its just going to beloud as shit
Honorary Administrator
That is alot of problems but they are all relatively easily fixed. If you spend one hardcore weekend on the car you would have it back into shape.
Discussion Starter #4
Well I have always wanted a Eclipse/Talon/Laser, and it just happened that I traded a second vehicle I had for it. I traded a 92 Jeep Cherokee with 169K on it and it's own problems. BTW the Laser has 107K.
Discussion Starter #5
I did some checking (as any newbie should do) for a couple days before posting. It appears that the window possibly could be fixed by cleaning contacts and window track. The lifters seems to still be in debate as to what works best. The engine probably is smoking because of valve seals, but isn't major.
I have perfomed one mod that I found on this site already. I removed the lower honeycomb in the intake and took the metal star looking device out of the end of the canister.
the silencer.... lifter tick can be fixed with the new style lifters... buy some rims and youll have all the same tires.... and youll get and alignment at the same time....go to the wreckers and get a new liftgate
1 - 6 of 6 Posts
